1972 OMC Tilt clutch issue (again)
hunt2labs
I've searched this forum for more detailed information regarding the operation of the clutch plates but could not find such information.
The outdrive is no longer supported by the clutch.
I have installed a new electric motor which operated the system fine without the weight of the outdrive.
I pulled the clutch plates-rusty and dirty with water and oil mixed. Worm gear appears fine, only 1 pin on the shaft (not 2 like later models).
So the plates are somewhat pitted and I wire brushed what I could without taking off the coating. I used brake cleaner then soaked them in oil.
Still not enough pressure to hold up outdrive.
What are the solutions?
New clutch plates and seal pack?
I will definitely be packing grease into the worm gear area after reading up on these marvels of design.
I may have a line on a local used clutch pack, which if clean may be the answer.
I saw that someone has used a pin in their clutch pack which probably is not a great idea if I hit a rock at speed.
Thank you
southkogs
I think for clutch pack parts you're going to be on eBay or CL. I don't think they're available any longer. So, take a look at that local pack for sure.
Check the retaining ring for flatness and be certain it is actually i stalled. If the ring is bowed (not flat) install it with the bow inward. Unless the retaining ring is installed the pack cannot work.
hunt2labs
Thanks-sorry for delayed response to my question. Retaining ring is on and is flat. There is another washer that is bowed inward.
Is this outdrive considered a 400 or 800 series?
1972 Stuery V815, 155 OMC engine
southkogs
Neither: It's an Electric Shift. 400 / 800 were used on the hydro-mechanical and mechanical shift Stringers.
hunt2labs
I've seen that engine list page but not the history page-thank you for that as well!
