I bought a 1990 Crestliner SST a few weeks ago real cheap. Hull is straight, no dents, but paint is in poor shape. The interior is trashed so it will be a complete gut job. I am planning on replacing all the foam and every piece of wood in it.
The Crestliners are fully welded so no rivets to deal with and I haven’t found any cracked welds so far. This one has the SST (space saving transom) extended transom. I’m still trying to decide if I want to replace the SST transom wood or not. It doesn’t seem rotten, but I probably will end up doing it just to know it is good. There really isn’t an ‘inner’ wood transom on the rear of the main boat. The SST is bolted to is bolted to kickers to tie it into the main hull structure/stringers. However, there is a piece of ¾” ply between the transom skin and the kickers which is rotten along the bottom edge. Not real sure the purpose of this other than to act as a spacer and maybe provide a little cushion between the two assemblies. It looks like a real PITA to replace this.
