Kzreelrods
Thread starter- Joined
- Oct 8, 2014
- 14
1998 Mercruiser model MCM 4.3 LH S/N 0L690518 I'm having an intermittent stalling issue that is the result of a lack of voltage to the fuel pump through the oil pressure safety switch circuit. I've been working on this issue for a while, and being intermittent, it has been difficult to diagnose. Some days the boat fires right up and works flawlessly all day long. Often, and usually before the engine has come up to full temperature, it will stall out and refuse to restart. Sometimes it will persist long enough where I call it a day, and other times after 10-15 minutes the problem will magically go away and the motor will run flawlessly all day long. Seems pretty random. I have spark and there is never a flooding issue when attempting to restart. When things are good, and I jumper across the oil pressure safety switch, the fuel pump will run when the key is in the run position (eg. There is voltage to the oil pressure switch). When the issue occurs, the fuel pump will not run when I jumper across in this same manner (no voltage to the oil pressure switch). Here is what I've done so far. - mechanic rebuilt the carbeurator (initially he figured this was the issue... Whatever). - fuel filter was also replaced. No indication of water in the fuel. - I re routed the fuel tank vent line to ensure no low spots holding gas and causing resistence. - I replaced the oil pressure safety switch - I replaced the fuel pump - I replaced the fuel line leading from tank to filter... Also verifying there is no antisiphon valve in the system. - I replaced the ignition key switch. - main wiring harness connection was pulled apart, cleaned, greased, and re secured. At this point, the problem seems to be electrical and seems to be preventing voltage from getting to the oil pressure switch / fuel pump circuit. I'd appreciate suggestions on further troubleshooting. I know the starter is also involved in the fuel pump circuit as well, but not sure what to look for there. Starter is very difficult to see / access. Thanks... Erik
