burchburch1
Thread starter- Joined
- Oct 10, 2014
- 1
My Bilge pump is not working. I have taken the following actions with no success. Tested to wiring at the pump location and am getting power. When I turn on and off the switch at the helm the light goes on and off. I believe this tells me three things. I have power at the pump location. The switch at the helm is working properly. And I have no fuse problem. I have hooked up a brand new pump motor and it won't come either. I have also turned upside down the automatic switch to makes sure it was not causing a problem. My understanding is that the automatic switch is hard wired to the battery and runs independent of the helm switch. Any suggestions for next steps will be appreciated!
Thank you
Thank you
