- Joined
- Mar 8, 2009
- 43,318
Well there is good and bad news. The good is I received a new HP transom assembly (0L915000), the bad is I missed one digit in the part number and got one without trim senders. According to what I've found is it appears to have only one sender which is mounted to the side of the bell housing. The sender operates off a lever which is attached to the pivot pin. So to install I need to figure out what kit (if there is a kit) to purchase. Then would need to remove the pins, drill and tap holes and complete the install.
Once installed need to figure out how the wiring would be done. Sender (863187A2) has three wires. I'm figuring a common ground and one would be the switch side and the other the gauge. In manual 28 it shows very little about it or the mating end.
