Willy, Thanks for stopping by. She does have good lines, hoping I can bring out the best of her.
Your MBS sounds like it needs some help. What are you looking for?
Mission Impossibly Stupid - Code name - Retrieve Ugly Donor - Was successful, but not without a small hitch.
Drove down and pulled the donor to the parking lot. Pulled each wheel, greased and tightened the bearings. Found one of the cotter pins was missing the head, replaced it with a finish nail bent to hold the castle nut. Changed the tires out with the ones from the Lone Star Big Fisherman. Was able to get one light working pretty quickly. Running with one working trailer light is legal in Michigan. Put a really big strap on it and headed home.
Stopped twice to check the bearings. Things were looking and feeling good. While floating along at 55 there was a load POW. Pulled off the two lane and found the passenger tire had blown.
Tire only had about 300 miles on it.
Not sure if it was overloaded (990lb tire) might have been close. The fender was bent away from the frame and sharp edges were pointed towards the tire. Found lot of rust between the fender and the frame. Thinking it may have worked loose and cut the tire.
Doing my best impression of a Viagra commercial, I calmly tore off the fender, pumped up the better of the original tires, and changed the tire. Was able to wind my way home the last 10 miles on the back roads.
So there is now another itchy boat darkening the boat yard.
