Tnstratofam, the bow stop actually damaged the bow from rubbing around over the years. Most of that was due to the slop in the tilt trailer hinge.
Jake, the sponson cradles will do the same ting in combination with the ratchet straps. The straps are rated at 1500 pounds working load and I should have 3 of them. Your point is well taken, and I may add something to the winch tower as a backup.
Thanks sprintst, I like to make sure I do things once....
Seacast is great to work with!
Got the tounge welded up and temporally put on the bunks.
All nice and cozy back on the trailer.
I have a few more fall chores, like welding up a couple of gates....so it maybe a few weeks before I get much else done. I would like to finish up glassing in the small pieces of deck forward of the toe board....and foaming them before it cools off. I'm also working on starting to build out the shop part of the hanger this fall.....always too many projects!
