Patt I think we can do without the CSM on the 6 pack holder, it seems to float nicely
I was heading to the lake tonight, but we had a cold (cool) front roll through. Alegedly we were going to get rain.....still don't see any....but since I stayed here I took advantage and did some work on Fuggly. Just to get everyone (and me) back to where I am, I need to get theforward bunk mounts on. I think this will help out a bunch with the boat squirming all over the trailer. I have improved that a ton, but I am still not happy. Hopefully this will be the cure, if not weld on more steel
I think this will really work well, if not I will box the c-channel frame members! But this should be the last step before pulling the motor and gimble housing. I need to do that to have good access to finish up the glass and body work around the doghouse. I also need all the drive off so I can paint the transom.
Here is the port forward bunk bracket. It was a LOT of cutting, grinding and fitting for something so small! The coping on the big tube was a pain.
I also cut out an fabricated the hard parts for the starboard bracket that I hadn't gotten to.
Here is the port bracket sitting on an angle that I am using as a jig. Tomorrow I am squaring it up and welding it in place.
I noticed that the boat was sort of rocking on the bunks, I'm hoping the forward supports (extending the bunks 2 more feet) will solve that problem. I wanted to do this and figure out where I am with it before pulling the motor. Hopefully a little welding tomorrow, pull the motor Sunday....and primer and paint soon!
