smassey22180
Thread starter- Joined
- Apr 15, 2013
- 210
I just upgraded to a different boat and went from a MC Alpha 1 to a VP SX. My new boat is silent on idle. I can barely hear the engine run. But once on plane it sounds like I am on muffs in the driveway. On muffs I can hear some of the exhaust coming out of the prop but most of it comes out the outdrive from these square cut out areas in the picture below. No water comes out these holes. Most water comes out the transom with a little coming out the prop. Is this normal for VP to be this loud? If there is a plug where is the most common area to look? I assume I should separate the upper and lower. I removed the prop and did not see anything there.
