alindquist
Thread starter- Joined
- Feb 21, 2008
- 82
2006 Formula 330SS with twin Mercruiser 496 mag's, smartcraft, DTS, serial 0w618143
So I'm stumped. I bought this boat in August and it has ran great so far. I decide to do a little maintenance this weekend and now I have a problem. I pulled the raw water pump to change the impeller. Everything went pretty smooth and when I had it back together I fired the engine up and no water was coming out the exhaust, and I'm showing no water pressure on the smartcraft. I pulled it all back apart thinking that I screwed something up but everything looks correct.
I pulled the pump back off and turned on the hose and I have no water coming out the intake hose where it would attach to the pump. Shouldn't I have water dumping in to the bilge at that point? It's a bravo 3 boat, is there a shutoff valve in between the transom assembly and the pump? I'm stuck, and help would be much appreciated.
Thanks,
Aaron
Thanks,
Aaron
