- Joined
- Mar 8, 2009
- 44,299
Alldodge, DTR member? Your callsign is familiar.
DTR is unfamiliar, if it is Diesel Truck Resource then I am not a member, I am a member or Dodge Cummins Diesel Forum
ALLDodge - People on DTR have linked to some of your threads. Small world.
What is the tension supposed to be like for the lower cable? Before I tear the drive apart to change the cable, I want to be sure its bad. I have pretty good tension pushing it in and out. It has the 3" of travel as recommended in the video. It does move with a moderate amount of force. Similar to an auto trans cable in a car. Just without the clicks. If the cable is supposed to move freely and fast, then I assume the cable is bad. Putting it in and out of gear does stop the propeller from moving in opposing directions. So I do know it is working as it should. I am leaning towards the controller or adjustment is way out. I may be doing something wrong. There is that threaded rod piece in the cable coming from the controller that adjusts in and out, then the brass nut tightens. (older cable) I am feeling there is an adjustment there I am missing and cant find in the video section.
