muskyfins
- Joined
- Jun 7, 2012
- 584
Just picked up a new to me 1995 Rinker Fiesta Vee 265 with a 5.7 bravo 1. I have a short time table to get her winterized.
When looking for drain plugs,....well, I couldn't find drain plugs on the manifolds. And the engine is pretty deep in the compartment, so although I was able to get my hands on the block drain plugs, given the fact it was a "blind" feel for the plugs, I didn't think it was prudent to remove what I THINK was a drain plug. Therefore I believe for the first time ever, i will have to winterize with the antifreeze through the muffs method. I know this is a hotly contested issue on I boats, but I feel a little against the wall here. Anyway, question is-since i already removed the thermostat, can I just winterize with it out and replace it in the spring? Does this ensure antifreeze gets everywhere? I'm pretty meticulous, so I'm not worried about forgetting to replace it.
Also, FWIW. Where should the seawater pump be? Always thought it was STBD side low mount? Nothing there. Just fuel/water seperator and fuel pump. No belts run to that side of engine.
