89 Bayliner Trophy with a no spark condition
James Tedder
Hello looking for BigBabyLou, I have an 89 Bayliner Trophy with a no spark condition and am wondering if the wire to the points are bad. I just put a new coil on and points and condenser. I need to know the voltage and resistence checks and should I perform a temporary ground to check for a spark?
Ayuh,..... Welcome Aboard James,..... Please don't hy-jack old threads, I started ya a new 1 here with yer posts from the old 1,....
In the future, for future problems, the start a new thread button is at the top left corner of the forum listin's,...
I also don't respond to PM's for boat questions, as that's what the forums are for,....
That said,..... Start in Don'S Adults Only section, there are 2 threads in there explainin' yer points ignition, 'n what to look for,...
James Tedder
Hello Bondo thanks, until I learned the page I did not know how to post a new thread. I have an 89 bayliner trophy with 3 in line solinoids and just put on another coil. I still have no spark to the points. OK I will follow your orders. Thank You
James Tedder
Hello Bondo, I did find the link and will follow that. It is mainly talking about a v8 and I have an 89 bayliner trophy hardtop 3.0 omc mercruiser. I did not see how to reply or make a new topic once the forum is closed.
Ayuh,... It's either an OMC, OR a Mercruiser, not both,......
A points ignition is a points ignition, 4 cylinder, 6, or 8,.... Still done the same,.....
'n Solenoids are parts of the Startin' circuit,...
Nothin' at all to do with the Ignition,....
This link should explain yer way through to findin' Why ya got no spark,...
