197? Selco Selstar renovation
Status
Not open for further replies.
Rjn
Hi everyone, i recently bought my first classic polyester speedboat.
Price was for the outboard engine, so i knew it had some work for the near future.
During the summer period we ( the family ) used it often.
Already had to do some work on the outboard engine to keep it running smootly, but this was easy fix.
After the summer pulled it out of the water and the first issues showed themself.
Probably nothing that can't be fixed, but it will be learning on the job.
As polyester work is new to me.
Thus the application to the iboats forum.
Picture time:
Rjn
On the trailer gutted the interior out, lots of rotten wood from the seats.
Took the wooden floor out which was on the polyester floor out, and tadaa the past repairs appeared.
No. good, small inspection done and the whole floor has rotten away.
Holes drilled in the bilge area????? And water sprying out when i walk there.
Rjn
No Title
Rjn
No Title
When it was still in the water
Rjn
No Title
Hull damage
Rjn
No Title
Interior incl rotten wood, and rotten floor
pckeen
Good luck with this restoration! I have to ask - is this polyester or fiberglass?
Rjn
Thanks, I would say polyester.
But i'm no expert.
So far winter is coming, well temperatures are going down a bit.
So plan is to clear out the hull, and sand the outside.
Prepare her for next spring, for the build up.
Does anybody here have information about the brand Selco?
Sofar internet didn't give my much information about this brand.
Rickmerrill
Good old fiberglass, what a word. I could use it a be talking about a fabric or a resin or the combo as in a fiberglass boat. I might be talking about "Fiberglas" marketed by Owens-Corning used for insulation. I might say FRP and mean fiber-reinforced polymer or fibre-reinforced plastic. I might say GRP and mean glass-reinforced plastic or polymer. So whatever you call it it all boils down to glass fibers and a polymer. Luckily we all usually know what they really mean!
Rjn
I'm still trying to find out what all the abreviations mean on this forum.
I live in the Netherlands, so i have to translate everything :)
kcassells
I figure if it's polyester it will shrink in the washer a little. Welcome aboard!!
Good plan so far cause the weather is achanging. Get as much grunt work done as possible, like you said abnd come Spring or a garage you can jump right back into it. Lots to learn here. Whats a Netherland? Only kidding.
Rickmerrill
I thought that was cotton? Oh, you did say a little... I thought Netherland was Michael Jackson's place? Sorry Rjn, we are just being silly!
Rjn
Whats a Netherland?g.
The netherlands is the main capital of Amsterdam, wich is in Danmark :)
Rjn
The cotton is probably on the inside:)
I can handle it! No worries.
Rjn
Not much done lately.
Did some sanding on the outside, anti fouling is coming off ok.
Found some more repairs wich where hiding under the anti fouling, but these look good.
Forgot to take pictures.
Oh, and while sanding the keel water appeared from under the keel, from the inside to the outside.
There should be a surprise under the floor waiting for me.
kcassells
Cool. So it's time to start ripping up the floor and knock out that nasty stuff. With that the temps don't care. Also Iffin you're doing that make sure you have a GREAT
waterproof cover to ptotect your work. You might slip around on the site and see some and who knows...work thru the cold winter.
Good ....now get some pics back at us Man! Thats how we all can help you out as we SEE what is going on.
Rjn
Good ....now get some pics back at us Man! Thats how we all can help you out as we SEE what is going on.[/QUOTE]
Weather is improving, so the power tools helped me shred out the wooden floor and started out removing old smelly foam.
Plenty of water in the wood and foam.😱, she should have loosed a couple of pounds when she is restored.😄
No rotten stringers or bulkheads found underneath the floor.
Apperantly it's a foam / wood deck construction.
The glas fiber underneath the foam is still in good condition, so that shouldn't require any work.
Will take pictures next time and update accordingly 😁
Status
