197? Selco Selstar renovation
Status
Not open for further replies.
Rjn
Fibers layed on the inside of the keel in front and back section off the boat.
Got all the holes and cracks sorted on the inside😄
Now working on the floor, ouch my back, getting in and out the boat for test fitting and cutting 😅
Also started sanding the outside off the keel, prepping for peanutbutter and fibers 😊
She's coming along, slowly but steady.
Rjn
been a while with the updates, but work is progressing.
pics i suppose will tell the story better:
putting fiber in;
prepping the floor panel;
putting it in with the peanut butter mix
fibers on it
prepping the dash to smooth it out
extra layer of fibers
new gauges to go in there after it is finished
test fitted the horn
filling up holes from the outside
before;
after;
now smoothening outside out, filled some more scratches and holes with the peunut butter mix.
need to put some layers of fiber on it to make it nice and smooth.
Rjn
Finally have the floor in,and have it water tighed ( forgot the camera so no pics )
Formed the bilge in the floor.
Up next is the foaming of the hull.
And then an extra layer of fiber to top it off.
Then the outside will be next :)
Rjn
Drilled holes in my new floor, and filled it up with 2 component foam.
Now the final layer of fiber and then she is water tight.
Already started on the interior, back bench frame done.
Now carpet can be orderd, not sure about the color yet.
Thinking about light grey or grey.
Will make some pictures Son.
Woodonglass
Has anybody SEEN rjn's work?? Do you guys think he's really been workin on his boat or is he just talkin about it?? I wonder??? Pix really tell the story doncha know!!!!:D
Rjn
pics of the progress:
Pics look a bit wors then it actually is, Due to all the color differances
now need to grind it smoother, ordered topcoat RAL9002 ( greywhite ) to finish it.
carpet needs to be ordered for the floor and finish the benches.
new cover and interior for the winter period to be sorted out.
Won't be boating this year, finish it before next season and then the whole year using it.
Woodonglass
Ok, Ok, I guess you REALLY did do some Work!!!:lol: Keep it up and you'll be on the water in no time!!!:joyous:
Rjn
topcoat is in, so now the inside is waterproof :)
bilge extra in the topcoat:
fitting the back bench, like a glove!
going for a grey carpet and black vinyl seating, that will be the next challenge for the inside.
the bench will become an L-seating.
now only fiberglassing the bottom and the dashboard and then finished with the fibers.
after that the outside can be attacked for a new paint job.
made the discission to keep the boat out of the water this years and finish it before next season.
young kids, holidays and work AND fixing up a boat has been a struggle on finding the time.
but slowly and steadily moving forward, and next year is only boating :)
Rjn
Long time since i've posted, however managed to do some work in between posts.
Benches are in, carpet lying is next.
Outside is ready for anti fouling.
In 10 days going on vacation, and after my vacation she's going to swim again.
Lets hope she stays afloat 😜
Rjn
vacation is over, so did some more work on the boat:
overview
some new details placed on the boat:
bench done
today putting the new NAME and Harbour stickers on.
putting in the carpet and then she's ready to go SPLASH!!
new color for the boat will be put on next year.
can't make a decission on the new color.
Tnstratofam
I've been following along and think your doing a great job. The interior is looking good. Look forward to seeing her back in the water as I'm sure you are as well.
Frey0357
RJ,
I like it, the lines on this boat look like its going fast when sitting still! Looks good, and its going to feel good cruising the seas once again, only dry this time!
Wow, ReD......how ever did you think of that?
Congrats :clap2:
Frey
Rjn
RJ,
Congrats :clap2:
Frey
My kids are called Ruben and Daan
And= en in Dutch
Therefore ReD
The color is just a coincidence 😜
Rjn
picked the boat up today, she's finally at home.
did some polishing work, and attached the carpet to the benches:
left side polished, right side on polished:
before:
final result: after half a spray bottle of wax and 1 sheep!!
carpet: ( don't mind the tooling )
Tnstratofam
Sweet!! She looks real good. The carpet turned out nice too. I'm sure it's good to have her home.
Really nice job!
Rjn
She's afloat!!
Had an issue with the outboard engine, it didn't go in forward.
So had to go backwards into the spot, readjusted the lever for the forward,neutral and backwards and now she's ready to go.
To bad the weather over here is s*~t, only rain.
First using the boat for the season, and then next year the electronics and painting.
Status
