Last week I took my boat out of the water and the ramp was quite shallow due to low lake level and I ran through a good bit of sand/mud, to the point that it killed the engine a couple times when I was trying to get it on the trailer.
Last night, while running the engine on the earmuffs, I noticed that there was no water spraying out of the typical spots (just at the transom and out the center of the prop) which tells me that there is mud/sand in the impellor and my engine is not getting any water. To further exascerbate this, I pulled the freeze plugs and very little water came out and what did come out was dirty. I am confident that this is dirt/sand and not oil or anything else, which leads me to believe that I have a clogged impellor…right? The engine never overheated and upon visual inspection nothing smelled hot, no oil or coolant appears to be in places it shouldn’t, and everything sounds fine.
I usually replace the impellor at the BEGINNING of every other season and have never had an issue before but I’m wondering if there is a way to “unclog” the system so I can winterize and ensure that no water is trapped in the system over the winter. My logic here is that if I replace the impellor in the spring, I will have a “new” part that didn’t have to sit in the elements all winter…does that logic pass muster? I live in Washington State so it can get down to 20 degrees or so in the winter.
If so, would anything be solved if I put the boat in the water to try and unclog it? My thought here is that the added pressure on the water inlets at the outdrive could free things up and get me through the winter. Is this valid logic?
I am conscious about the importance of this part and system and want to make sure I give it the attention it deserves…if I mess this up its going to cost me thousands!
Engine is 5.7L w/ Alpha 1 outdrive and freshwater exchanger. Any insight or advice is greatly appreciated.
