Price on 4.3 exhaust manifolds?
philbullet
Came across these on ebay,seem to cheap for alum..Can this be true?
itrm #371148310268
tpenfield
It is Michigan Motorz . . . check their web site. Same thing. Not sure about the quality of the HGE manifolds versus some of the higher priced brands.
philbullet
No thumper not at moment, in process of a rebuild and may convert it to coolant.i also need some exhaust manifold and risers, was just looking around.
curious ,why u asked? Thanks.
thumpar
Aluminium and salt is a no go. Aluminium and raw water can work but may cause problems. Dissimilar metals without antifreeze cause corrosion problems.
achris
More fish than mountain goat
Exhaust manifolds and elbows are very much a 'get what you pay for' item. If you find cheap ones, they are cheap for a reason.
As for converting to closed cooling... Only if the engine block is less than about 20 hours or 1 year in salt, after that forget it, too much build up in the passages.... You'll be cleaning the heat exchanger regularly (like every 2 months!) and dealing with constant overheats...
Chris........
Ayuh,.... Ya get what ya pay for,....
I bought a set of GLMs, 'n had to machine the riser matin' surface Flat to stop the leak into my motor,...... :rolleyes:
philbullet
So I see there's different name brands.
Which one or good and bad?
achris
Basic rule, OEM is the top of the heap, GLM is WAAAAY down the bottom...
Howard Sterndrive
looks like Dry Joint Manifolds with old fashioned Risers. I can't make sense of the pics in that auction.
achris
No, if you have a closer look you can see the water passages on the elbow mounting surface... And I wish people would stop calling exhaust elbows 'risers'. Merc call them elbows in all of their documentation. Risers are the small extensions that lift the elbow up for engines in low laying installations. They come in 1.7", 3", and 6"...
