- Joined
- Mar 8, 2009
- 43,659
Here is another plus for carbs. My Rinker has around 650 hours and I only replaced the plugs, cap and rotor near the end of last season. The plugs looked great (Original champion) and the reason behind it was the carb is working correctly. Only issue I have with it now is caused by not using it, only about 10 hours a year over last 7 or 8 years.
Yours just like mine can run rich and show no signs of codes. Steam cleaning the engine is bringing back the numbers, but I still see it as an old engine and it won't be long before it is back where it was. New or old the MEFI-1 is a bare basic EFI system, while it does work, if symptoms start to show, you can do little to determine what is causing the issue(s). It's either replacing parts, pulling injectors and have them professionally cleaned or swapping components if you have twins.
