Smtred
Thread starter- Joined
- Dec 6, 2014
- 48
To start I would like to note that this boat has been passed onto me, after my grandfather had passed away earlier this year. This project has sentimental value and I want to make sure I do the best job possible. My previous experience with boats is actually with this boat years ago when he would take us fishing and water skiing. However that is all besides the posts I've looked through on this site. I am pretty handy and can figure most things out, however a little direction would go a long way for this project.
Here is a look at what I'm working on
The arrow points to this water logged area
Here is a better picture of the same area at its worst point
Here is a couple close up of cracks in the floor
Looks pretty bad...
After the research I have done it does seem as tho I will need to replace the whole floor. If there is a better solution I am all ears. I'm not to sure where to really start if that is the case there is foam underneath the wood as well. I was able to see it from where I took the seats out. There is much more to be done besides the floor as well but I will worry about that after the fact. The Engine is solid had it checked and tested at a shop. The Transom area is still solid and good as far as I can tell from what I've read. Any help would be much appreciated and I will be uploading some pictures of the whole boat later on to give a better example of what I'm working with.
Looks pretty bad...
