- Joined
- Mar 8, 2009
- 44,078
Personally I think the jack plate may be causing most of your issue. Most folks that use them are the bass boats which are able to lift the hole boat out of the water except for maybe about a foot square. The jack plate should be able to position the cav plate directly even with the bottom of the keel to no more then 1 inch above. Here is a good read
http://media.channelblade.com/boat_...s/dts/dealerlibraries/8441/copetipstricks.pdf
