Wont start
scatgo
Can someone PLEASE help me find a wireing diagram for my boat. No spark again. This is going to put me in the funny farm.
Ayuh,.... The wirin' diagrams are in the Merc manuals,...
The links to the Merc manuals are in Don'S Aduts Only section,....
scatgo
Hate to be a pest but I cant find that link. You sure its still there?
Ayuh,.... ------------ADULTs ONLY -------------------------No Exceptions----- > Mercruiser Information > Service Manuals
While you may not be able to download them from this link, you can look at them and get the info you need.
Boatinfo - The library, containing manuals, brochures and other technical documents from the last hundred years!
Still works for me,....
Just What's got ya stumped,..?? Startin', or Ignition,..??
scatgo
Just put this coil in a month ago, Got it off ebay for 15 bucks. It came with a ballast resistor but I didnt wire it in thinking the boats resistor wire would be fine. I only use this coil a few time to start the boat and now no spark. I find it hard to belive the coil smoked already but I just need to get some thing straight with the wires like finding out what wire has the ballast in it. Still trying to find out why it is overheating so I am sure you an see where something like this would flip me out. Well back to the square one. I just hope I can get this all sorted out before it gets much colder. Thanks and happy new year
Speakrdude
Ensign
The easiest and one of the cheapest tools you can own is a spark tester from Harbor Freight tools. $4.95.
Troubleshooting is king!
Plug in tester, Do you have spark? Yes, move on. No, go back and test per the service manual. Sensor in distributor is a common failure point.
Happy New Year!
scatgo
Points were toast. Need to get the ballast resistor in there. Get full 12 v at the coil. think it should be 9. Should be a wire at the starter that gives the coil a 12 v kick when starting. Just need to sort this all out then one day look into a conversion to get rid of the points.
scatgo
O yea. A keg of beer to the guy who helps me find the right wiering diagram. My boat DOES NOT have a ignition amplifier and it DOES have a volt meter not a amp meter. More hints on the way as soon as I figure out how to post pictures.
Bt Doctur
From manual #3
