This is an Inboard/outboard boat... Not that much stress on the transom, right????? The steps are solid, the stainless steel rail is solid as well. I drilled three pilot holes down low on the transom and mounted the speedometer pick up... Again, all solid. I removed the thru transom steering cable. Yup, that was solid too. All the carpet is in great shape, and I have no plans of replacing that, just the vinyl. I have replaced many of the screws for the captains chair and the in-floor ice chest. No rotten wood there either, as all screws had plenty of meat to grab. I have removed panels for cable removal, and everything seems solid.
I've been in home remodel and repair for 22 years... I've seen hundreds if not thousands of water damaged projects. I've lost track of how many bathroom floors I've had to cut out and replace because of water damage. All that being said, you guys are scaring the HELL out of me!!!
In regards to the OMC power plant, I've had no problems there. Between Go2Marine, Ebay, Colorado Boat Center, and BRP, I've been able to locate o rings, drain plug gaskets, a thermostat, steering conversion kit, tilt motor gasket, etc. I've even looked up replacement parts that I don't need. If something major goes, I'd consider a swap for newer units. Not saying you're wrong, it did take work to line up those connections. It just so happens I enjoy the "detective" work.
This is my new hobby. My wife told me to get a hobby! Ha ha ha If I just wanted a hole in the water to throw money in, I'd have bought a new boat. That being said,can we turn the tables to a more positive note? What should I do? What should I look for? We've been out 12 - 15 times over the summer. We've had 13 people on it at one time! It still got up and plained out! We've been it 3 foot chop at near full speed. I just don't see or feel any soft spots. Perhaps I'm just not looking in the right place? I don't really want to tear the carpet out just to look at the decking.
Thanks for the feedback guys!
