gm280
- Joined
- Jun 26, 2011
- 14,605
I know exactly what happened with the bow in the table. I did something similar once making a very nice yard sign with our last name and house numbers on it. I used 2 by's planed, jointed and glued together to assemble it. Then routed out everything to a depth of about one inch deep, but the house numbers and name and a border around the entire sign so they appeared raised. Then I used a wood gouge to take chunks out of the base wood to give the appearance that it was hand cared that way. Absolutely looked amazing...UNTIL the difference in moisture in the wood took over. It arched in the middle because that is when the wood was the thinnest. I didn't figure on that and should have used a backer of plywood to keep it flat and straight. Lesson learned... Seems you did basically the same with your cut out sections as well. The wood arched the same because your cut sections out...
