monette999
Thread starter- Joined
- Jul 8, 2011
- 35
Dear Forum,
I have decided not to go with an marine intake. they are very expensive. A 2104 is about $130 USD & 2506 is $350.
Hard Coating is $40 Dollar. Will use an std intake, but will alu hard eloxating the intake. This ensures always a nice outer finish.
Using my boat only on fresh water.
Since I always had hard starts when engine was hot I would like to hear you experience with the CrossWind Type of intake.
Will it increase the height of the engine & will it cause a package issue with a Edelbrock 1409 and flame arrestor.
Currently I am running a stock mercuiser 2bbl and flame arrestor.
Looking for your feedback.
Greetings Bob Hard eloxation / hard anodizing
Hard eloxation is a variation of anodic oxidation in which layers 25-200 ?m thick are created. The hard eloxal technique generates a very hard, ceramic-like surfaced on the aluminum with high wear resistance. The pressure resistance of hard eloxated aluminum surfaces is comparable with hardened steel or hard chrome layers.
This method, used especially for technical applications, creates surfaces in colors ranging from grayish brown to anthracite to black (depending on the aluminum alloy). Hard eloxating is suitable for wrought alloys and for cast alloys (die casting, chill casting). This method is not suitable for producing sharp edges.
Advantages
Advantages
- Ceramic-like surface
- Layer thicknesses of 25-200 ?m
- 50% increase in the thickness of a lawyer
- Tolerances up to ? 10 ?m
- Very high, even hardness up to 500 HV
- High level of wear and abrasion resistance
- Very high corrosion resistance
- The eloxal layer is electrically nonconductive
- Reduced thermal conductivity
- Outstanding adhesive surface
