FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Does anyone make a SBC marine aluminum housed circulation pump thats designed for raw water cooling? I know Dennis Moore used to make them, but has since discontinued due to lack of sales. Any info would be great
I'm still raw water cooled. edelbrock 8819 is all anodized aluminum with non steel impeller and ceramic seal. Thing is its a short style pump but the hub height is 3/16" further out. So that would require shimming all the pulleys out as well. Pilot shaft is also thicker 3/4" over the standard 5/8". Which if you want to mod everything it would work well... I might just go with a standard iron pump for installation ease. I've already removed ~110 lbs off the engine with new exhaust and aluminum intake that's holding up just fine with raw cooling in fresh water
I had to shim my pump pulley and crank pulley... no big deal. You can add some thicker pump gaskets too if needed. I'm running Al intake, circ pump, timing cover, valve covers and SS manifolds (6lbs ea.).
