sphelps
- Joined
- Nov 16, 2011
- 11,508
gm , the M/F if I get brave enough to try will be going on the Borum Bobcat ..And thats gunna be a while before I start that project .. I figured with the compressor that I have the hvlp will be my best bet on doing a good job with the gelcoat going on the Manatee .. If I had a bigger better compressor I might have sprung for the gell dump gun .. The larger tip should help with laying down more material ..
This hull was in really bad shape .. Even the factory gell .. Hopefully with the extra time I am spending on the prep it will help with the final sanding and buffing of the new gell ..
I am wondering what grit I should use for the final sanding to prepare for the gell adhesion . I,m thinking at the most 120 ... I would think you don,t want it too slick ..
Any one have a formula for figuring how much gell to buy .. Roughly 20,160 sq inches on just the bottom ... I guess it will take at least 4 coats or more to get the proper thickness ..
