64osby
Thread starter- Joined
- Jul 28, 2009
- 6,826
My project came with and old Stewart Warner temp gauge. It reads 140 not hooked up. Markings are from 100 to 240.
Trying to figure out if it is shot.
My understanding is that this a 12v system and the temp sensor would limit the voltage from 0 to 12 volts depending on the temp.
As it sits it has no voltage but reads 140. I can hook it up to 12 volts and it will go past 240. Disconnecting the voltage it slowly works it way back to 140.
I'm thinking that an electric temp gauge should either read low (100) or be pegged (240+) when there is no voltage. Is this a good assumption?
For this gauge to read 100 it would need negative voltage.
Thanks for any help.
