Need some measurements on a 16SS
MNhunter1
I'm about to order my Nautolex for the Nova and was hoping to fit the excess material for the top of the gunnels and bow cap on the 16SS, which unfortunately is in hibernation for the winter. Does anyone know:
The width of the gunnel tops on a 16SS?
The length of a 16SS bow cap piece?
I'm pretty confident I'll be able to squeeze the floor and both gunnel tops out of the 72" width, but want to order enough length to fit the bow cap piece in there as well.
Thanks!
Tnstratofam
I may be able to check mine this afternoon if it doesn't snow today. Mine is covered, but the cover is pretty easy to undo.
MNhunter1
Given some further thought, I think I should be fine with 6 yards, unless the bow cap is much over 36", which I don't think it is. 5yds will leave a little extra from the <15ft floor of my 15ft hull, so a 6yd order will give me an extra 36" and change from the floor.
dozerII
I've got the old bow cap and gunnels for the Naked Lady laying in hanger I will measure them when I get home from the office.
InMotion
MM --- 6 yards is what I used for a 16' Jup.... so that should be good for you as well.
J.
dozerII
Bow cap measures 52" wide by 24"front to back
Rear sections of the gunwale tops are 107" long by 6" wide
Front sections of the gunwale tops are 66"long and 6" wide but with the curve take a 10.5"arc.
Hope that helps
MNhunter1
Hope that helps
Perfect! Thank you all for the help.
