Alumarine
- Joined
- Feb 22, 2005
- 3,745
Hi there. I have a slight leak in the water pocket cover gasket.
I thought I'd check to see if the Water Pocket Cover was leaking.
The cover does not look melted in any way.
I followed the instructions that achris mentioned in a previous post
"Remove the drive and separate the 2 halves. Rig up plugs and hoses and pressure test the water pocket cover.. Spray with soapy water around the edges of the cover... You see bubbles... you know the rest...."
Ok, I got bubbles. I didn't hook it up to an air supply, I just blew in it while plugging the outlet.
I have very, very tiny bubbles along one edge of the cover. I didn't notice them at first.
Knowing the danger involved, I carefully tried to loosen the bolts using a 3" long 1/4" drive.
3 of the bolts loosened easily and of course one didn't budge.
I've been doing the heating, banging and spaying with PB blaster - no luck.
I'm very tempted to just leave it alone and see what happens.
What do the more experienced think?
