- Joined
- Oct 25, 2011
- 25,240
Several have reduced the size of the splashwell, esp in the models w/ the GIANT wells, to get a bit more deck space.
IIRC, a few have also reduced the size of the apron across the front of the splashwell, it's a fairly wide flange across the top, so unless you need that flat space for riggings or rod storage, you can trim it back too.
Changing or removing the splashwell also leaves the tin short below the gunwale, which ties to the front of the splashwell.
Swamping and structure are 2 fairly good reasons to leave a well of some type, just be sure you can tilt the motor fully if you trim the well down.
