Kagee & or Boomer-O/D woes more info
KaGee
Re: Kagee & or Boomer-O/D woes more info
Originally posted by jh19:<br /> Do you have any thoughts on the above water pump issue? Thanks
There's only one way to find out... Pull the drive and split the upper from the lower. When you do, you can access the pump and remove it. The shaft condition will be obvious.
whywhyzed
Banned
Originally posted by jh19:<br /> If the shifter / throttle puts the drive in gear by meshing the ball gears
The ball gears NEVER unmesh. Shifting happens in the lower unit only.<br />The hydro unit is an oil pump in the lower unit that builds hydraulic pressure. The shift cable operates a "valve" that sends the pressure to a hydraulic piston that mechanically engages you in F or R (I think that's basically the deal)<br /><br />Later drives skipped this step and the cable hooks directly to the F/R mechanism<br /><br />skipping?<br /><br />are we sure the ignition isn't cutting out or something.<br /><br />If the drive shift out of gear under load, that's gotta tear up the gears, no? I'd think you might get 1 or 2 free ones max...
Phantom17
Thanks for the explanation, thats what I wanted to know. First, the boat never jumps out of gear. It skips for a second. No loud bang or thud. Feels like a slipped prop might feel, but I tried 2, it's not slipping. <br /><br />Second, What is the grinding sound when you put it in gear? Is that the gears in the lower unit? I am real gentle when putting it in and out of gear. I was told the sound is normal. Hopefully this weekend I'll yank the drive off.
whywhyzed
Banned
Originally posted by jh19:<br /> <br />Second, What is the grinding sound when you put it in gear? Is that the gears in the lower unit?
yes, lower unit gears meshing makes that sound
KaGee
Should be more of a growl than a grind.
