sumocomputers
- Joined
- Feb 23, 2015
- 123
EDIT: Changed Temp Sensor to Thermostat.
I have a 1989 Johnson 70, and it has a very specific overheating issue at certain RPM ranges. I don't have a very good understanding of how outboards work, so forgive me if I am missing something obvious. I am really looking to see if what I am observing is normal, and if not, what type of troubleshooting list I might go through.
Here is the summary:
When running at around 5 MPH (No Wake Speed) for a few minutes in the San Diego Bay, which is around 1500-1800 RPM, the newly installed Sierra temp gauge/sender will stay steady at about 210F. This seems very high.
The sender unit is the type that just threads into the engine block, and was bought with the temp gauge, with a new sensor wire installed.
When just idling, which is around 800-1000 RPM, the temp will stay steady at about 180F. This seems kind of high, but not too bad.
When anywhere above 2000 RPM, the temp drops to somewhere between 120-150F, even WOT. This seems normal.
I have a new warning buzzer installed, which does work when grounding the factory temp sensor tan wire to ground, though I have not tested the sensor itself, as it seems a little bit involved. The buzzer never goes off when the temp gauge shows 210F at the engine block. I suppose this could be because the engine block temp is probably not the same as the factory one that is internal (water jacket?).
I did recently disable the VRO2 system and now pre-mix at 50:1, but had this same problem before I did this, so I don't think it is related to lubrication.
Based on the little research I have done, it seems like might be related to the impeller, water pump, or thermostat, though I am not sure what does what. I do know the tell tale produces a strong stream at any RPM, and I am pretty sure the previous owner had a new impeller installed recently (I have an email out to him confirming).
Is this temp behavior normal? If not, could someone help me begin troubleshooting with a short list of likely candidates? I do have a Factory Service Manual, and consider myself mechanically inclined, and have worked on cars in years past.
Thanks,
Chris
Thanks,
Chris
