compusolver
Thread starter- Joined
- Mar 8, 2015
- 11
Strange problem - '79 Johnson 15hp (Model: 15EL79E) always ran great, starts right up, etc. Was starting to sputter at top end, so I replaced the fuel pump, but now when I hit the starter button, it won't turn over, or even make a sound. I may not be tracing the electric circuit correctly, because although I'm getting voltage at the starter (when I press the Start button), I get the same voltage even when I put it in gear. The only wiring diagram I can find is for slightly older models and shows the big red wire going first to a neutral switch, then to the starter. But my red wire goes straight to the starter, with a second wire going to a row of wires on the other side of the motor. I'm thinking I may have accidentally done something to mess with the neutral safety stuff, but I have no idea what that is and I can't find any mention of neutral safety for this model (which I think is basically the same as the 10hp). I've been to http://www.leeroysramblings.com/Johnson 9.9_15.htm, etc.
Can anyone suggest anything that might put me on the right track?
Also - I've disconnected the shorting switch to eliminate possibility of a problem there.
