Sea Rider
Thread starter- Joined
- Sep 20, 2008
- 12,345
For the experts, scenario ;
450 Rib
Deep V hull
400 Kg : Rib, driver, engine, fuel (minimum loaded)
Engine Tohatsu 2 stroke 18 HP engine
Well trimmed and deck ballanced
Wot rpm range : 5200-5800
Data :
To maintain plane 20 Km/H
Cruise speed : 35 Km/H 4.5K rpm
Wot : 5600 rpm
Wot speed : 41.5 Km/H
Delivered Prop : 9.2 x 9.1 (9 pitch)
Flat glassy no wind water cond.
2 stages to plane, 1/2 throttle untill Rib is on its way, 3/4 throttle to plane with just driver.
This sib is rated for 7 passengers and 50 HP engine.
Usually go boating with min 2 up, max 3 up driver included. So no need a larger HP engine, would like a prop maximization.
If going 1 less pitch to 8, (9.2 x 7.8 ) theoretically should pull up my revs + 300 revs to be at 5,900 ( slight over rev.no big deal. Max wot rpm will dercease accodingly as soon start carrying more weight or add boaters aside from driver.
Question :Will my hole shot improve a bit along my top wot speed if revving at 5.900 solo ? Usualy like running at cruise speed on flat calm days, but like having my horses running near full wot rpm factory stated.
There's a 8.5 pitch alternative (9.2 x 8.8) that should put me around 5,750 rpm. Should I choose the 8.5 or 8 pitch prop for best top performance ?
Happy Boating
450 Rib
Deep V hull
Data :
Wot : 5600 rpm
Happy Boating
