Trouble getting at the spark plugs properly. Mercruiser 165 alpha one 3.7l
H@ystack
I'm trying to put new spark plugs in this engine. The angle is so odd and with parts of what i believe to be the coolant system in the way, I cannot get a straight shot to the plugs (especially stern side). I was able to get one out with hundreds of 1/64ths turns on the socket, but that clearly isn't practical. Am I missing a good tool out there or something? I've tried 3 extensions, no extensions, and 2 spark plug sockets.
I'm hopeful someone knows what I'm trying to describe and has experienced this or there is just some magical socket i can grab that I've never heard of.
Bt Doctur
you need to grind/machine away the hex part of the socket and use a 3/8 ths universal joint
stonyloam
You need to use a box end wrench on the hex end of a spark plug socket. Slip the socket over the plug first then the wrench on the socket. Yeah #4 can be a pain! You might be able to get a ratcheting box wrench in there, don't know, never tried it myself.
H@ystack
Thanks so much. I knew it was just a concept of "needing the right tool". Even a slight angle and you're snapping spark plugs left and right. I've worked on a few older engines. I had a straight 6 1984 F150, and it was a straight shot to those things, so this a rather new experience, and seemingly such a simple fix I couldn't wrap my head around.
stonyloam
Just don't drop #4 plug behind the engine, I did and took 2 hours to fish it out with a wire loop, then dropped again, only took about 15 min the second time LOL! It also may be easier if you take the rubber insert out of the socket.
wrestling coach
Well my 470 is an '82 and it has been most useful getting some angle on my four plugs. But I don't find any of them too hard to get to other than a straight shot right down on the plug. The rubber hose makes the install a lot easier though.
Dennis
Brock.Ward
I recently did mine started by hand tightning it then getting the hex swivel in there and tightening it to specs, then I had just enough room to pull out the socket...
stonyloam
Dennis
Yeah I have an "87" so the reservoir is larger making things a little tighter in there.
johnzonh
had the same issue with mine...had to carefully feed a u-joint in there to get at them... a pain but it worked.
H@ystack
I ended up just putting a spark plug socket (rubber gasket removed) on the spark plug by hand. Then, as someone mentioned, just put a wrench on the end of it. Such a simple fix. Funny how one never thinks of such simple solutions unless you've ever seen it done before. I got the plugs in, wires done, new coils, and caps and it purrs like a cat......like a 30 year old cat, but still. :)
Thanks for the help! I know it wasn't necessarily a "boating" question, but more of a mechanical question.
