Thanks for replying. Whats happening is my hydraulic is actually being eaten away. The drain screw for my trim fluid actually had to bre replaced because of it. This motor doesn't have a spot for a zinc above the intakes so i put a " U " anode on where the lower unit connects to the motor but don't think that is helping. I don't have any for the transom brackets and not sure there is one made to fit. I've only seen the little zinc which is connected to the side of the transom but on the inside by the hydrolics. As you suggest maybe i need to look harder for something that can bolt to the bottom of the transom. Something similar to my 225.
OK then. You have a model with power tilt or tilt and trim.
I think tbishur may be thinking along the right lines.. An electrical problem rather than any deficiency of the anodes.
There are a number of variations listed so get the model number and go to the relevant diagrams on the BRP, or other, parts website and check that all grounding cables are in place and making good connections.
Also check the general state of the electrics,looking for shorts to ground and bad connections especially of negatives and grounds.
If you leave the boat with a power supply hooked up while in dock, for battery charging perhaps, this could be causing problems if not fitted with a galvanic isolator or zinc saver
