muskyfins
- Joined
- Jun 7, 2012
- 587
My thought is....you thought you were dealing with a reputable dealer......didn't know there was such a thing!!
WOW.....just wow
I like to put forth the best info I can to those who might benefit from it.
Just because I disagree with, or feel I have something to add to, something you said does not mean I don't think you or anyone else knows anything...
That said, the rollers absolutely DO have a weight rating hence the reason the manufacturer told the O/P that the number of rollers on the trailer indicated the weight rating to be 2/3 of what he thought it was..
Too much weight per roller will deform the hull and the roller.... Bad news
Upgrading springs does nothing for the rest of the components on the trailer that are overloaded....
I am not attacking you and you give plenty of good advice in these forums but you got this one wrong.... No need to go on the warpath.
I've been wrong too and stood corrected. We are, after all, human.
On larger trailers with heavier boats, I use bunks and not rollers.
Interesting thread, nice passion displayed. I would be more worried about what abuse the boat itself has "seen" being on not enough rollers for it's whole life. I also imagine that some small pro-rated dollar amount settlement may be obtained for an upgrade, but only be just enough to make the effort required to obtain said settlement end up a wash.
Just to claify, the boat has only been on this trailer for the last six months, prior to that it seems that the boat had one owner who keep it on a lift on the same lake as the dealer I purchased from. The po may not have taken the original trailer or got rid of it as some point since he didn't need it.
The local dealer who I am purchasing the Shoreland'r from is going to inspect the hull when they have the boat up in the air doing the transfer.
Last fall I purchased a 1991 SeaRay 225BR after having it surveyed and a Seaworthy test. The boat was deemed to be in very good shape. This well known SeaRay dealer was selling the boat/trailer as a package like most. The boat has a dry weight of 3900lbs and close to 5000 when it is fueled and ready for the water. I was told that the trailer had a 6000lb capacity (which is noted on the sales contract as well). A few weeks ago after moving the boat a few miles, I noticed one of the roller support arms had broken off and the hull strake was resting on the support damaging the gel coat.
I called ezloader to inquire about replacement parts , gave them the vin since the trailer plate was too worn out to read a model number and they tell me I have a 4000lb capacity trailer. The fact that it only had 24 roller should have been a clue to both the dealer and myself.
I contacted the dealer, told them the situation, they said they didn't have a used one available but would discount me on a new one. I'm located a few hundred miles away and told them that I won't pull the boat on this trailer and that I would prefer they purchase the trailer back so I can find a local one.
They have agreed to this but are offering very little in my opinion. I believe I should be entitled to the markert value price of a 6000lbs capacity 1991 tandem galvinized trailer since this is what they told me I was purchasing, as well as the cost to transfer the boat to a new trailer, plus the cost to repair the damage to the hull (getting a quote this week) plus compensation for having to go through all this when I should have been supplied a trailer that was suitable and set-up properly for the boat in the first place.
Opinions appreciated.
