Chemdawg
Thread starter- Joined
- Aug 31, 2013
- 112
Hello. I have a 1980 Evinrude 4.5 outboard motor Model E5RHCSS Serial E0001388. I installed a home made troll master onto this for use as my kicker motor. The troll master works great, but I'm really confused. The hand tiller is disconnected inside, so the throttle should not work. AT LEAST that's what I thought. IT doesn't actuate the carb, but it does cause the throttle to change. I noticed that there is a ring going around the flywheel with a wire connected to it that turns with the throttle on the tiller handle as well. What is this? It appears to be some kind of timing advance or something. Ideas?
