swapping aq131a / 275 leg out for merc 4/3L
nogamesjoe
I have a 1986 bayliner trophy and I plan on taking out aq131a and 275 and putting in 1986 merc 4.3L using merc. adapter plate 827691a1 I made a template but as you can see in pics it does not!!!! just bolt in and later found that these adapter plates are only for 270 outdrives.. can I just cut out and fill old holes be good to go ? will plate be in right place and work ?
achris
More fish than mountain goat
My preference would be to take the hull to a good fibregalss guy and have him completely fill the existing hole and recut it for the Mercruiser... Use an 'X' height of 13-9/16".
nogamesjoe
did ya see pics sorry being side ways but it looks like all is needed is to fill old holes and cut some out at top wouldn't ya think
achris
The pictures didn't make much sense. Is the current hole smaller than the hole required for the adapter plate?
As for it putting the Mercruiser gimbal housing in the right place, all I can suggest is you measure the distance from the bottom of the adapter to the centreline of the crankshaft and transfer that measurement to the hull and make sure it's 13.625" vertically up fro the bottom of the hull...
nogamesjoe
yes it would need cut out as you can see in pics and I sure will use the x spot measuring your talking about so drive line is IN LINE thanks so much . joe
achris
The important thing is that 13.625" measurement is NOT along the transom, but up from the line of the bottom of the hull at 90 degrees.
nogamesjoe
Thanks so much achris the info you provided will get the job done THE RIGHT WAY Awesome!!!! and I found that only!! the alpha gen 2 will bolt up to the adapter plate
achris
... I found that only!! the alpha gen 2 will bolt up to the adapter plate
If an A1G2 will bolt up, then anything after about 82 will bolt up... The only difference between Alpha One and the Gen II in the hole requirements is the A1G2 requires 2 additional holes at the top.... All the other holes are the same.
