I have returned... with a Starcraft this time!
jbcurt00
Dont copy them, just use them as inspiration, or make some changes so they arent copies....
besides, you're not offering COPIED logos for sale, simply a 1 off for your own boat....
ok, 2 off since you'll need 2, 1 for each side...
I liked the 1 I posted because its clearly got a fish in its beak. Thats gotta be good luck on a fishing boat, right?
BWR1953
Good luck is always appropriate for a fishing boat! :nod: :encouragement:
BWR1953
Well, my wife foolishly went to work this morning and ended up having to come right back home a couple hours later, so I was minding her until I picked up the boy from school in the afternoon.
But with the boy in tow, I headed out to the garage to see what could be done with that blotch.
We tried the Xylene with the wire wheel in the drill, but that didn't work very well.
Then I took a really good look at the hull and I'm thinking that the blotch was road rash mixed with the old paint and which corroded the aluminum. Or maybe the aluminum was anodized and the shiny stuff got knocked off while trailering? And there is a ton of road rash. Like 42 years worth. Makes the hull look "freckled" below the spray rail.
I FINALLY GOT IT REMOVED. Well, I started getting it off the hull. We spent just a short time in the garage because I wanted to get back to m'lady and make sure she was okay. But the process was working.
I used Mineral Spirits and the little triangular Scotch Brite pad with the handle. I started scrubbing and the scratches and blob started to reduce. When I started seeing the MS turning black, I knew I was hitting the aluminum pretty hard.
As I was demonstrating and explaining to the boy about what I was doing and that we'd have to do the entire hull that way, he said "Why?" I replied "Uhhh... because the surface has to be properly prepared for paint." At that point he said "Why?" again and pointed out that we're not going to paint the lower underside of the hull. Hmmm... :lol:
When my wife and the weather are both improved, I'll work it harder to see how it goes.
Big chips, little chips, scratches and grooves abound.
wAAACH5BAEKAAAALAAAAAABAAEAAAICRAEAOw==
Freckles.
After some scrubbing with the MS and Scotch Brite pad. Not finished, but progress made!
And now we come to the keel. It has chunks torn out of it from years of rough service. This is in the area which will not be painted. Suggestions on how to improve?
Watermann
I like your paint scheme and the KF logo is a cool idea.
The pics didn't come along with your last post.
BWR1953
Dang. I'm sitting in a treatment chair at the VA right now and can't address the pic issue. I'm on my phone and I can't see the pix either. I won't be home until later this afternoon. :grumpy:
BWR1953
Let's see if this works. On my phone. Keeping my fingers crossed. :rolleyes:
Freckles.
M2HB
Maybe you could get a welder with an aluminum spool gun to fill. Then it would just be a simple task of dressing it up to it’s original shape.
I would keep a wet rag around it so the surrounding area doesn’t get too hot. I wouldn’t want too much expansion around the rivets.
jbcurt00
Welding to fill in and reshape the keel, esp near where the bow plate diamond meets the actual keel strip (a well known leak site) wouldnt be my 1st or 2nd choice.....
expanaion arpund the rivets would be secondary to the seam.sealer used behind every seam....
BWR1953
Yeah, that concerns me too. Don't want to melt my Gluvit! :eek:
Watermann
I used marine tex to fill and reshape my SNs battered, cracked and abused keel. Tough stuff but easy to sand.
BWR1953
Yeah, I thought of using JB Weld (or MT) to fill and reshape the bumps, but that area of the keel will be unpainted. Wouldn't look too good. :grumpy:
BWR1953
I could always paint it like this. But I don't like it as much. Not as "clean" looking.
BWR1953
Kingfisher logo?? :lol:
Monmouth00
My keel wasn't in horrible shape, but it was scuffed from rubbing on countless trailer rollers. I thought about other colors, but decided to go black to hide any further scuffing, plus a layer of textured bedliner to better hide al the small imperfections.
Maybe it will work, maybe it won't. Time will definitely tell.
Decker83
Get some aluminum paint and just touch up where you use the MT or JB
Waterman used some aluminum paint on the bottom of his hull and it looked great..
BWR1953
As expected, yesterday I caught the flu from my wife. :sick: For some odd reason it didn't knock me on my butt like it did her. Maybe cuz my butt's so much bigger than hers? LOL! :lol:
Felt a bit better today so the boy and I went out this afternoon and FINISHED stripping the KF! :nod:
We did it in 4 sections this time since we didn't have as much paint to remove. Worked fine.
Applied the stripper, waited 15 minutes, then scraped, brushed and then wiped.
