BWR1953
- Joined
- Jan 23, 2009
- 6,513
The boy and I went out this morning hoping to do a link & sync. Didn't happen. While checking out the flywheel timing marks, I decided to bump the motor over a bit with the starter so that the pointer would line up.
Turned the ignition key and got nothing. I recalled that while we were out on the water last time that I'd gone to start the engine but got nothing at that time. Figuring that I'd not fully returned the throttle/shifter to neutral, I moved it forward and back and after that the motor started normally.
So this morning I tried the same thing and got zip. Zilch. Nada. Sigh. :grumpy:
My instincts lead me toward the neutral safety switch as being at fault. The starter solenoid could use replacing too, but it's been working okay. I'll do the full troubleshooting bit to make sure I fix whatever "it" is.
Meanwhile, back at the ranch, I quickly found a replacement solenoid but spent HOURS searching for the NSS part number with no joy.
This evening I hollered for help again over on the Mercury forum.
