sdowney717
Thread starter- Joined
- Jul 16, 2011
- 249
I notice when I turn the key to on, the oil gauges move up to read maybe 10 lbs? Without the engine running.
I have mechanical gauges and they read normal, about 10 to 15 lbs higher
I checked the sender ohms, and it reads 120 ohms with engines off, so they are dual station senders.
I swapped in a new gauge and it responds like the old gauge.
Do your oil pressure gauges move when you turn on the ignition switch?
I will check the senders and wires out some more.
