oregonducker
- Joined
- Feb 10, 2004
- 189
1998 22' Wellcraft CCF.
Fresh batteries (even tried a second set to rule that out) but several things aren't working. I have 13 volts everywhere I've checked but pumps won't come on. Nor will the anchor windlass. Nav lights and the motor work but that's about it. The anchor windlass wiring and the livewell pump are easy to get to so I disconnected them at the pump and windlass, turned their respective switches on and I get 13 volts between the wires. Plug them back together but neither work. Took a separate battery and ran test leads directly to the wires at the pump and it runs fine. Same with the windlass. All of this stuff is from one distribution panel including the nav lights.
Things that aren't working - bilge pump, fish box pump, livewell pump, deck lights and anchor windlass. All the switches have 13 volts.
Things that are working - Nav lights and engine but the engine is pretty much separate from the rest of the electrical stuff.
Any ideas on what do to next?
