mobisware
Thread starter- Joined
- May 21, 2015
- 24
Went to take the boat out recently. Started up ok, noticed the tell tale flow looked ok, let it idle while packing on the gear. After 5 - 10 min, I noticed the water stop flowing out the tell tale. I turned off the motor and got a little smell of burnt oil. After letting it cool off I hooked up the muffs and noticed a dribble out the tell tale. It started up ok and had a very strong flow out the tell tale for about 5 - 10 min. Then the pitch of the motor dropped, I looked back and there was no flow out the tell tale. I turned off the motor and got a little smell of burnt oil. I attempted to inspect the thermostat however it looks like someone else already took it out. I don't know how to check the pressure relief valve. Any tips would be appreciated.
