1992 Johnson 150 VRO Engine Running problems
Thewagen
I can get the engine to start (after winterizing for a few months, now with new spark plugs) if I apply some throttle, but when I try to set the throttle lever to IDLE (Neutral) position, the engine quits. I can re-start as long as I give it some throttle, but each time I try to put throttle lever in Neutral, the engine stops. What's the likely cause? We recently had removed the gas tank, filtered the fuel, and re-installed and re-fueled (with the same gas). Also, when throttled, the engine runs better in a raised (tilted) position then when it is lowered all the way...What gives???
mfkadz
It sounds like a cylinder is not firing. You might want to pull the plug wires and reseat making sure the connector inside is lined up. If you have a timing light you can hook that to each wire and check for flashing light. My guess is one will be dark.
mike
boobie
Or you can pull one plug wire off at a time with an insulated pliers and see if you have a dead cylinder.
Thewagen
mike
But when I apply throttle it acts/seems like it's running great. It's only when in neutral that the engine quits. A bad plug/cylinder can cause that???
Thewagen
It ran fine as late as December...all I did was winterize by pulling the plugs, Putting very little oil in the cyclinders (Recommended to me), cranking the engine to get the oil distributed, re-seat the plugs,, and leave the wires 'off' for the winter...Now the engine decided to be stubborn...
mfkadz
You betcha.
On the muffs and in a tub it seems fine as there's no load. On the lake with a bad cylinder you will not get the speed you had. On my 55 I get 25 kts when ok and 8 kts with a cylinder out.
You can check this for sure by pulling a plug wire one at a time. The test is to see if it makes a difference. If a cylinder is out you will notice no change.
mike
