Good afternoon folks,
Now, i should start off with saying this... I'm not sure that it was the motors fault hahaha...
I was looking at purchasing a boat from my mother, a 18' maxum with a 3.0 merc. I dropped it off in a lake, jumped on and took off. Ran great. After boating for about fifteen minutes and making it to the middle and cruising at 80% throttle, it died on me. I immediately brought the boat back to neutral and attempted to restart. fired right up. However, if i attempted to put it into gear, neutral or reverse, the boat would stall. It felt as if something along the drive line seized up.
Initially i thought it was a spun prop or a bad coupler. However, after getting pulled out of the lake and loaded back on to the trailer, i started observing the prop. At that point i noticed a hole, about 3" in diameter, on the front side of the lower unit. It seemed as if someone loaded the boat with the trim down and smashed it against the ramp.
Could this be my issue? and if so, how much damage could be done?
Now please keep in mind, i am no mechanic, but am comfortable enough with my abilities to pull the lower unit.
I appreciate your help.
Thank you,
Sam
Thank you,
Sam
