Bonus Check
Thread starter- Joined
- Apr 19, 2015
- 162
I have the Super Lube hubs withe the rubber end caps and the zerk in the center of the shaft....whenever I launch/dunk the trailer I remove end caps and add 2 strokes of grease to zerk to expel any water from hub. The rubber plugs seemed to crack/deteriorate/maybe leak, so several years ago I purchased some neoprene Bearing Buddy Bras to go over the hub caps to protect rubber caps from UV/cracking/leaking and as a double water seal....works great so far!
I have new hub caps to cover the grease caps so hopefully that will protect the rubber seals from UV degradation.
