85 Johnson 140 thermostat, removing cup and seal
cycleman
Hello, anybody know to remove the cup & seal located under thermostat's?
Thanks, Bill...
gm280
Here is a break down for your engine...
Looks like parts 90, 92, 93 and 94 are all part of the thermostat Hope this helps out... JMHO!
cycleman
Thanks gm280, ....What I need to know is how to remove 48 & 49 from where they are seated.
I'm removing the flow control valve and assorted hoses and replacing it with 1993 thermostats and covers. I have all the parts, just need to know a good way to remove and install new cups & seals.
cycleman
Problem solved:
Since the cups were really, really snug, but in good condition; I elected to leave them in place. I removed the old seal thru the cup opening, cleaned things up inside and then squeezed new rubber seals into place.
gm280
Problem solved:
Okay, great to see you're making progress now. I have never ever worked on your type engine so I didn't have any procedures for you to remove those parts. But you now have that experience to give to others when they ask for it. And that IS what makes these forums so great. The combined experiences of all the members... :thumb:
cycleman
Well put, thanks for your input :joyous:
djpeters
I have the same exact motor but an Evinrude. Whats the reason for going with the '93 parts?
cycleman
These old loopers have a "flow control valve" located behind the throttle assembly. This valve is connected to the throttle and controls the water flow thru the thermostats based on RPM.
My flow valve was leaking and new valves are no longer available. Seals for rebuild are also listed as "no longer available"
I searched this site and came upon the 93 upgrade.
djpeters
Ahh. Thank You. Good to know!
