1987 200hp jet identification
toybuilder039
On a 1987 200hp which jet controls idle air/fuel mixture? Top or middle? Mine is running rich plugs wet at idle. And does bigger jet = leaner fuel mixture
V153
Top. Last I checked bigger jet equals more of everything: Air & fuel?
boobie
Lower one is for idle. Top is for intermediate. A bigger jet equals less fuel (leaner, more air). For a bad idle on that motor you may also want the check the recirculation valves. There's a procedure in the factory service manual. Been there.
V153
Hmm?
toybuilder039
Thanks guys I have checked the recirculating valves. And replaced 3. Seemed to help some but the lakes I typically fish at are idle speed only and tired of this thing loading up. Going to try to drill out jets.
boobie
If you have the right drill bits you can do it. Jets are about $10.00-$12.00 apiece
toybuilder039
I fiqure it's worth a shot worse case is I would have to by 6 jets. Think I'm going to try to go up .010 and see if it idels better
V153
It's your motor.
'Magine if'n ya had a jig rigged up & a good drill press. And good sharp correct sized bits. Ya might could get away with it.
But we're talkin 1/100"?
Boy I dunno. Let us know how it works out.
Faztbullet
Jets are not drilled!!!! Drilling can leave swirls in the brass and actually change the flow of jet, jets are reamed to size...
