Can water leak in where trim/tilt hoses pass through the hull?
supercab78
I have a slow water leak into the hull (about 1/2 gallon an hour) in 1993, 4.3 v6 gen II setup,, low hours & all fresh water use. It is stored on a trailer. It is not either bellows(new now but they weren't bad upon disassembly), trim wires or speedo tube. From what I can tell it's coming in BELOW the exhaust tube that passes through the transom. Yes the drain plug is tight. I can not find an exploded view or a picture of how the tilt lines pass through the transom. Is it even possible for it to leak water in there?
Bt Doctur
It might also be the transom. Take a screw driver and on the inside of the transom down low, try to push it into the transom, real hard. If your transom is solid you will not be able to push it in. Hope it's the manifold as BTdoc illustrated.
supercab78
Obviously I'm hoping for the trim manifold. I'll check the transom but the boat has been inside or outside with a good cover all of it's life. Y PIPE--- don't want to hear that one, Thanks for the illustration Bt Doctur that gives me some hope for the easy fix.
supercab78
As a follow up, I got lucky it was just the trim hose manifold gasket. Thanks everyone!!
